how to configure ip policy route-map at router
Can some body tell us if this configuration is o.k.?
we are applying access-list and ip police route-map to redirect traffic to other next-hope but when we use show access-list we can not see any match.
int fastethernet 0/0
     ip address 10.128.10.1 255.255.255.252
     ip policy route-map ZZZ
int fastethernet 0/1
     ip address 10.5.0.0 255.255.0.0
access-list xxx
permit 10.5.0.0 0.0.255.255 10.2.0.0 0.0.255.255
route-map ZZZ permit 10
match ip address xxx
set ip next-hop 10.5.106.1
when we use show access-list we do not any match.
when we use the command: ip access-group xxx in the interface 0/0 we can see matchs when we use show access-list xxx.
Question: we have to use the command: ip access-group so ip police route-map can work?
Waiting your answer.
Roger
Jon Marshall
Roger
If you use "ip access-group ..." you are applying the acl to the interface. You don't need to do that with PBR, you simply use it in the route-map.
Your config looks wrong though. You want to PBR traffic from 10.5.x.x which presumably comes in on your fa0/1 interface because that has a 10.5.x.x address so you should apply the policy map there but you have applied it to fa0/0 ?
PBR must be applied to the interface on the router that the packets arrive on.
Jon
