how to configure NAT with 3 routers.
sivared0001
The traffic between the loopback 0 interfaces of R1 and R2 should traverse through R3;
R3 should be configured such that it translate 132.10.10.1 to 171.1.1.1 and 132.11.11.1 to 173.2.2.2
You can do NATTING only R3 router.
After completing the solution you do the verification.
Verification
On R3:
R3#show IP NAT translation
Pro  Inside global          Inside local        Outside local          Outside global
---  ---                    ---                 173.2.2.2              132.11.11.1
---  171.1.1.1              132.10.10.1            ---                    ---
R1# Ping 173.2.2.2 source 132.10.10.1
It should be ping
and when your ping comes then your R3 result should be change
ICMP  171.1.1.1:15          132.10.10.1:15      173.2.2.2:15           132.11.11.1:15
Note : Run OSPF protocol and you can use only one static route of any devices.
29 Replies 29
i configured ospf in 3 routers and i used area 0 for all after that inside and outside configured like you said above but still not able ping
R1:ping 173.2.2.2 source 132.10.10.1.
when i see nat translations still getting same
 As I said, you are not going to ping, for a simple reason. The IP address you are ping does not exist anywhere,, soon, you can not ping.
 But, you can ping and when you see the ping failure,, use the command to see the nat translation.
 If I undertood correctlly, what your instructor wants is to see the NAT translation, not the ping response.
The NAT will take place, with ping response or not.
Now, if you want to see ping responde, you can add a fourth device after R3 and configure the IP 173.2.2.2 on it.
Hello
The natted ip address(s) dont have to exist for you to be able to ping them, with NAT you can use any addressing as long as they reachable towards the NAT router, in this scenario the NAT router IS aware of them, The spoke rtrs just have a default route which will arp towards the NAT rtr.
Kind Regards
Paul
exactly so if we want to ping any address that address need a device so that means in my question ping task is error
Hello
I had to lab this one up TBH - It required some policy based routing and nat on a stick.
PBR because there is only one physical interface for the nat domain so we have to utilize the loopback interface of the nat rtr.
Please review attached file:...
Kind Regards
Paul
first both R1 and R2 default route must point toward the R3
ip static 0.0.0.0 0.0.0.0 R3
second config R3 interface & LO with ip NAT enable not NAT inside Outside, this make traffic hairpin in LO enter then NAT then Out
this my opinion for this issue.
Hello
@MHM Cisco World  Domain-less nat is an alternative if the ios on the rtr supports it but as this scenario is nat on a stick im not sure it would work - however i haven’t tested it so could not verify.
One of the reasons it could work is the nat order of operation is changed - with NVI nat a route lookup is perform before and after nat translation which isn’t the same as in domain nat.
Kind Regards
Paul
i have to use only one static route and also ospf i dont known where to use ospf.
ip nat enable command not working i got options only inside and outside to select after ip nat
first regarding to OSPF and default route,
config the default route in R3 and redistribute it into OSPF,
second for ip nat enable this command config under interface not in global mode.
sivared0001
Task-1:
R3#show ip nat translation Pro Inside global Inside local Outside local Outside global --- --- --- 173.2.2.2 132.11.11.1 --- 171.1.1.1 132.10.10.1 --- ---
the above one is done, i got exactly same.
the below one i have to do,
TASK-1:
It should be ping
i used for nat
ip nat inside source static 132.10.10.1 171.1.1.1
ip nat outside source static 132.11.11.1 173.2.2.2
i dont known how to solve the task-2,there are 3 steps
1.when i try to (Ping 173.2.2.2 source 132.10.10.1) from R1 the reply should come.
2.where and why to use ospf (mentioned in above note)
3.where and how to use only one static route of any device (mentioned in above note).
Iam sharing my commands in the attachment.
Hello
Why are you reluctant to use the solution provided?
Implement the attached and it will work
Kind Regards
Paul
i did everything in the attachment that you provided
until now everything fine now i need to get like below when we do below ping but that is nat address so we cant ping, then what to do now to get the final show ip nat translations.
Hello
can you attach the readout of the below commands into a file and attach to the post please
r3/r2
sh ip int brief
sh ip route
sh ip ospf neighbour
nat rtr
sh run
Kind Regards
Paul
prashun457
Help me, I'm not able to ping 173.2.2.2 source 131.10.10.1
