how to configure NAT with 3 routers.
sivared0001
The traffic between the loopback 0 interfaces of R1 and R2 should traverse through R3;
R3 should be configured such that it translate 132.10.10.1 to 171.1.1.1 and 132.11.11.1 to 173.2.2.2
You can do NATTING only R3 router.
After completing the solution you do the verification.
Verification
On R3:
R3#show IP NAT translation
Pro  Inside global          Inside local        Outside local          Outside global
---  ---                    ---                 173.2.2.2              132.11.11.1
---  171.1.1.1              132.10.10.1            ---                    ---
R1# Ping 173.2.2.2 source 132.10.10.1
It should be ping
and when your ping comes then your R3 result should be change
ICMP  171.1.1.1:15          132.10.10.1:15      173.2.2.2:15           132.11.11.1:15
Note : Run OSPF protocol and you can use only one static route of any devices.
29 Replies 29
balaji.bandi
the description clearly says that you do NAT in R3, that means , R3 connected to externally.
You can use below example, change as per requirement.
interface x/0
ip address y.y.y.y  255.255.255.0
ip nat outside
interface x/1
ip nat inside
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat inside source list 1 interface FastEthernet0/0 overload
BB
not working
To help better, post the config as attachement instead of screenshot.
BB
not supporting the gns config files to send in attach
Hello
The NAT solution I provided also shows how to configure OSPF
Its provides each spoke rtr with a default route from ospf, it also creates two static routes for the nat addressing (required) lastly policy based routing is applied as you only have a single physical interface on the nat router for translation, as such it uses also it own loopback interface for the two nat domains.
Kind Regards
Paul
 What you did so far?
Router(config)#ip nat inside source static 132.10.10.1 172.1.1.1
Router(config)#ip nat inside source static 132.11.11.1  173.2.2.2
Router(config)#interface fa×/×
Router(config-if)#ip nat inside
Router(config-if)#exit
Router(config)#interface ×/×
Router(config-if)#ip nat outside
i did like you said but not working please check my replies to known my issues
You are using the wrong interface for inside and outside.  I did answer above.
sivared0001
R3 has two interfaces one is e1/0 and loopback0
so i gave ip nat inside for e1/0 and ip nat outside for loopback0
task:
when i try to ping like above i am not able to ping
when i check nat trasnlations  i am getting only inside global and inside local and not getting outside local and outside global like mentioned in the question.
 I think is the opposite.
Loopback is inside and e 0/1 is outside.
Outside is the interface your leave the router.
still getting same error even if i change inside and outside i am not able to ping from R1# Ping 173.2.2.2 source 132.10.10.1
can u check in your gns or packet tracer
Export your GNS3 project and attach here, I can take a look.
But, look, who is going to reply? Have you think about that?
Where the IP address 173.2.2.2 is configured?  As per your topology, you should have one more device with this IP address.
Make sense?
the topology was correct we should not change anything in topology
translate 132.10.10.1 to 171.1.1.1 and 132.11.11.1 to 173.2.2.2 one is for R1 and one is for R2
 what about this note, what to with note?
I got it.  Try this:
R1
conf t
router ospf 1
network 131.45.43.0 0.0.0.31
network 132.10.10.0 0.0.0.3
wr
R2
conf t
router ospf 1
network 132.11.11.0 0.0.0.3
wr
R3
conf t
router ospf 1
network 132.13.13.0 0.0.0.3
interface Ethernet1/0
ip address 131.45.43.3 255.255.255.224
ip nat inside
duplex full
interface Loopback0
ip address 133.13.13.1 255.255.255.252
ip nat outside
