how to configure NAT with multiple outside (due to backup)
nicolasblain
I want to configure NAT for a customers with a ISDN Backup.
His primary link is on a Dial (PPPoE) and the secondary to (backup ISDN).
Do you know how to configure such a thing.
Thank you in advance.
Nicolas
spremkumar
Level 9
Level 9
hi
i feel u require something similar to this ..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087bac.html#52760
this is given with the example of ethernet interface try putting them on ur dialer interface and if ur using PAT then tweak the ACLs as well as your nat translation statements accrodingly..
regds
ankurbhasin
Level 9
Level 9
Hi Nicholas,
Here you go with the sample config which may help you out
route-map NAT-PPPoE permit 10
match interface
route-map NAT-ISDN permit 10
match interface
ip nat inside source route-map NAT-PPPoE interface overload
ip nat inside source route-map NAT-ISDN interface overload
Ankur
