How to configure "Right to use Licence" in ASR 1002
I am trying to activiate Firewall/NAT Stateful Inter-Chassis Redundancy License on ASR 1002
As per cisco documentation the below mentioned commands should support on asr1000rp1-adventerprisek9.03.07.00.S.152-4.S.bin
but i am unable to find any commands starting with Licence
1. enable
2. configure terminal
3. license boot level {adventerprise | advipservices |ipbase}
4. exit
5. copy running-config startup-config
6. reload
here is the output of my router
Router(config)#license boot level ?
% Unrecognized command
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.2(4)S, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 23-Jul-12 19:01 by mcpre
IOS XE Version: 03.07.00.S
Cisco IOS-XE software, Copyright (c) 2005-2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
System image file is "bootflash:/asr1000rp1-adventerprisek9.03.07.00.S.152-4.S.bin"
Last reload reason: Reload Command
Can any 1 help me out for the following issue or should i open a TAC with Cisco
0 Replies 0
