1941 router - VTI
a.hajhamad
Level 4
Level 4
I'm in process of purchasing a new Cisco routers for our branches that will be used primary to enable IPSec virtual tunnel interfce with "tunnel mode ipsec ipv4".
my question is:
- does the default IOS IP Base supports this feature? or i need to purchase DATA license or SECURITY license?
thanks in advance
The DATA-license doesn't include IPSec-VPNs, only the SECURITY-license. But you could use the DATA *and* the SECURITY-License to have even more features. But for this router SECURITY is enough.
If the image is not orderable, you only can download the image. But you can't purchase them from cisco. But that's not needed in your case where you only need to purchase the license for SECURITY.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
For all kinds of IPSec-VPNs you need at least the SECURITY-License. That's not included in the Base-Lic.
If you want to find out which license is needed for which feature you can use the feature-navigator:
http://www.cisco.com/go/fn
thank you.
i followed the feature link and i found i need either (SECURITY) or (DATA & SECURITY) does this mean the DATA license can fit our needs? since i think the SECURITY license is expensive than DATA
in addition, what is the Orderable column?
thank you
