How to configure RV325 to forward from one port to another?
jtbullitt
The RV325 can forward incoming traffic in a given port range to a particular IP  address in the local LAN. (This is done in the Setup > Forwarding config.) But I would also like to translate this traffic to a different port. Is it possible to do this with the RV325? I don't see this option anywhere in the setup menus.
are you referring to PAT (Port Address Translation, page 37 of the attached user guide) ?
https://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/administration/guide/en/rv32x_ag_en.pdf
@Georg Pauwen : Yes indeed! Somehow I missed that. Thank you.
