how to configure the following for my project so please check the attached
amralrazzaz
Level 5
Level 5
dear i need help on how to configure the following for my project so please check the attached :
3 Generic Network Services
3.1 Device Hostnames
3.2 Device Access
3.2.1 SSH and Remote User Access
3.2.2 Local User Access
3.2.2 Banners
3.3 Authentication, Authorization and Accounting (AAA)
3.4 Network Time Protocol
3.5 Device Logging
3.6 Simple Network Management Protocol
3.7 DHCP Relay Agent
3.7.1 DHCP Relay for end-user hosts
3.7.2 DHCP Pool for Access Points
5.3.1 EtherChannel and Trunk Interfaces
5.3.2 Access Interface
5.3.3 Loop Prevention
5.3.4 VLAN Trunking Protocol
5.4 Logical Layer 3 Design
5.4.1 IP Connectivity FTD Security Appliance
5.4.1.1 Directly Connected Routes
5.4.1.2 Default Route
5.5.2 IP Connectivity Core Network
thanks in advance for help
amr alrazzaz
balaji.bandi
All covers in easy steps by steps as long you understand all the technologies.
If you not familiar with the deployments, you need to hire Professional services, who can make implementation plan for you and deploy and KT done.
BB
BB
thanks a lot for help
amr alrazzaz
can i asked u if this is the design attached :
i need 7 vlans
4 for production , 2 for management and 1 for transit vlan
what is meant by production vlan like what ? need examples
aslo management vlan for what ?
should i have to use vlan wan transit between FW and and isp router and vlan  for lan transit between core switch and FW ?
amr alrazzaz
