How to configure two 6506’s for Redundancy.
lawrencejones
I have two 6506s with one “WS-X6K-SUP2-2GE w : 5.1” pre device. I would like to set these two devices in a redundancy topology, meaning if the primary 6506 failed the secondary (standby) 6506 will take total identity of the failed 6506, including moving all the running configuration information.
Can someone please tell me the best way to make this happen and/or point me in the right direction so that I can research?
SHOW MOD IS THE SAME ON BOTH DEVICES:
WS-C6506 Software, Version NmpSW: 8.2(2)
Copyright (c) 1995-2004 by Cisco Systems
NMP S/W compiled on Apr  7 2004, 12:09:03
System Bootstrap Version: 7.1(1)
System Web Interface Version: Engine Version: 5.3.4 ADP Device: Cat6000 ADP Version: 5.0 ADK: 40
System Boot Image File is 'bootflash:cat6000-sup2cvk9.8-2-2.bin'
System Configuration register is 0x2102
Hardware Version: 3.0  Model: WS-C6506  Serial #: SAL08332DYP
PS1  Module: WS-CAC-1300W    Serial #: ABC08232025
PS2  Module: WS-CAC-1300W    Serial #: ABC08232027
Mod Port Model               Serial #    Versions
1   2    WS-X6K-SUP2-2GE     SAL083742B0 Hw : 5.1
                                         Fw : 7.1(1)
                                         Fw1: 6.1(3)
                                         Sw : 8.2(2)
                                         Sw1: 8.2(2)
         WS-F6K-PFC2         SAL08373W54 Hw : 3.5
                                         Sw :
                                         Sw :
2   16   WS-X6516A-GBIC      SAL08342XAE Hw : 4.1
                                         Fw : 7.2(1)
                                         Sw : 8.2(2)
3   48   WS-X6148-45AF       SAL08186FS3 Hw : 1.0
                                         Fw : 5.4(2)
                                         Sw : 8.2(2)
         WS-F6K-FE48-AF      SAD08250552 Hw : 1.2
                                         Sw : 8.2(226)
4   48   WS-X6548-GE-TX      SAL1126SAPN Hw : 11.1
                                         Fw : 7.2(1)
                                         Sw : 8.2(2)
15  1    WS-F6K-MSFC2        SAL08342LA6 Hw : 2.8
                                         Fw : 12.1(22)E2
                                         Sw : 12.1(22)E2
       DRAM                    FLASH                   NVRAM
Module Total   Used    Free    Total   Used    Free    Total Used  Free
1      262144K  82831K 179313K  32768K  14484K  18284K  512K  306K  206K
Reza Sharifi
Hello lawrence,
If you had 6500-E, you could pair them together and create a VSS bundle similar to 3750 stacking, but unfortunately you have none E 6500, so that is not poosible.
You also have to have the right sup to do VSS.(Sup-720-VS)
Reza
lawrencejones
Thanks you
