How to connect 2 networks with different class address
dgcmorelli
I'm studing some network configuration and I need some help:
I've got 2 network configuered as:
Network 1:
DLINK DIR-300 Wireless access point with a IP: 172.16.0.115
One computer (Computer 1) wireless connected to this access point.
Network 2:
Linksys WRT54G Wireless access point with a IP: 192.168.0.1
One computer (Computer 2) wireless connected to this access point.
I would like the Computer 1 be able to connect to the Computer 2.
How can I do it ?
Do I need to add some router between the two networks ?
If yes, which kind of router ?
Thank you for your help
Best regards,
dgc
Istvan_Rabai
Level 7
Level 7
Hi Davide,
You need a normal router and you also need a so called Wireless LAN Controller.
Yyou can find a lot of information about wireless on the following pages:
http://www.cisco.com/en/US/products/hw/wireless/index.html
Also, there is a Wireless section on the Netpro discussion forum starting page.
Cheers:
Istvan
Hi Istvan Rabai,
what do you mean by normal router ? Have you got some reference ?
I've seen one called RVS4000, do you know it ? Do you think it can route a network IP address class B to a class C ?
cheers
Davide
Hi Davide,
I don't know RVS4000.
All Cisco routers are able to route traffic between any classes of addresses.
Depending on the traffic volume and other features you need, you have to select a router that best suits your needs.
Here's the link for you to search by features:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Istvan
Hi Istvan,
I'll have a look to your link .....
Cheers
Davide
