How to create access list to stop the 10.x.x.x from communicating with the 172 Network
acheak9975
Hi I have a router that is connected to two networks the 10 network is where Internet comes in. The 172 network is my local lan. How do I create an access list to stop the 10 network from communicating with the 172 network?  The 10 network cannot see the 172 network but 172 can see 10. I still need Internet access through the 10 network. Just want to stop all local traffic from crossing. I really need to figure this out as soon as possible. Thank you.
pieterh
how-to configure depends on brand/model os version
please specify more detail
look at this document: IOS Zone Based Firewall Step-by-Step Basic Configuration
I am using a 2900 series router 2960 switch both are on iOS 15
the Zone Based Firewall mentioned by 'pieterh' is the right solution. Check if you have any 'zone' config commands:
2900#conf t
2900(config)#zone ?
If that is the case, post your running configuration, so we can help with the details.
