how to define sampling rate in netflow of cisco ISR4431
atmaram.sahu
I have configured netflow on cisco ISR4431 but not getting anyoption to define sampling rate. looks like bydefault it is running @ 1/1 packet sampling.
Below are the configuration I have done...
Please suggest how to define sampling rate...
cisco ISR4431
Cisco IOS XE Software, Version 16.06.04
flow exporter EXPORTER1
destination x.x.x.x
source GigabitEthernet0/0/2
transport udp 5000
flow monitor MONITOR1
exporter EXPORTER1
cache timeout active 60
record netflow-original
flowspec
int GigabitEthernet0/0/2
ip flow monitor MONITOR1 input
Thanks for quick reponse & solution.
can you configure a flow sampler map ?
ISR4431#configure terminal
ISR4431(config)#flow-sampler-map sampler-map-name
ISR4431(config-sampler)#mode random one-out-of sampling-rate
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/netflow/configuration/xe-3s/nf-xe-3s-book/nflow-filt-samp-traff-xe.html#GUID-C9A46E0B-9962-4DAB-9211-731AE996B66D
