How to Delete Crash Info in 1760 Router
ranjit123
Level 3
Level 3
Dear All,
How to Delete or Squeeze crash info in 1760 Router as after deleting the file and power recycling the router then also the crash info files are not getting erased.
IOS Version is c1700-k9o3sy7-mz.122-11.T10.bin
<Branch name>#show ver
IOS (tm) C1700 Software (C1700-K9O3SY7-M), Version 12.2(11)T10,  RELEASE SOFTWARE (fc3)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 23-Oct-03 11:43 by eaarmas
Image text-base: 0x80008124, data-base: 0x80D52B4C
ROM: System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
ROM: C1700 Software (C1700-K9O3SY7-M), Version 12.2(11)T10,  RELEASE SOFTWARE (fc3)
AHM-531359000-VADEJ uptime is 2 days, 20 hours, 13 minutes
System returned to ROM by reload at 15:34:05 IST Tue Nov 9 2010
System restarted at 15:41:47 IST Tue Nov 9 2010
System image file is "flash:c1700-k9o3sy7-mz.122-11.T10.bin"
cisco 1760 (MPC860P) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FOC08201HDH (2236892604), with hardware revision 0000
MPC860P processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
2 Low-speed serial(sync/async) network interface(s)
1 ISDN Basic Rate interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
<Branch name>#show flash:
System flash directory:
File  Length   Name/status
  1   7468180  c1700-k9o3sy7-mz.122-11.T10.bin
  2   242658   crashinfo_20081018-114946 [deleted]
  3   275631   crashinfo_20081019-154335 [deleted]
  4   313176   crashinfo_20081024-213723 [deleted]
  5   309597   crashinfo_20081025-213251 [deleted]
  6   341415   crashinfo_20081025-221708 [deleted]
  7   357246   crashinfo_20091218-183910 [deleted]
  8   322700   crashinfo_20091225-183501 [deleted]
  9   316752   crashinfo_20100101-183506 [deleted]
10   347023   crashinfo_20100108-183054 [deleted]
11   341259   crashinfo_20100115-085927 [deleted]
12   345515   crashinfo_20100528-124730 [deleted]
13   419944   crashinfo_20100609-111723 [deleted]
14   367613   crashinfo_20100915-094525 [deleted]
15   404164   crashinfo_19930301-000110 [deleted]
16   428227   crashinfo_20100915-162418 [deleted]
17   356660   crashinfo_20100915-173401 [deleted]
18   346269   crashinfo_20100915-181414 [deleted]
19   345534   crashinfo_20100915-192756 [deleted]
20   346702   crashinfo_19930301-001010 [deleted]
21   400716   crashinfo_19930301-000110 [deleted]
22   413461   crashinfo_19930301-001540 [deleted]
23   342847   crashinfo_19930301-001536 [deleted]
24   343949   crashinfo_20100915-205704 [deleted]
25   346639   crashinfo_20100915-223404 [deleted]
26   419506   crashinfo_20100915-231021 [deleted]
27   419490   crashinfo_19930301-011456 [deleted]
28   348367   crashinfo_20100916-025817 [deleted]
29   331575   crashinfo_20100930-113741 [deleted]
30   338705   crashinfo_20101007-185140 [deleted]
31   333105   crashinfo_20101029-152914 [deleted]
[18036652 bytes used, 15517780 available, 33554432 total]
Ranjit
Leo Laohoo
Have you tried to format the flash?
Dear leolaohoo,
If i Format or Erase flash all the contents of it will be deleted i only want to Erase + remove crash info files.
Ranjit
Alright then.  How about "squeeze flash:"?
Hi!,
We have tried the same also but the IOS does not support the command
#squeeze flash
% Invalid input detected at '^' marker.
Regards,.
Ranjit
