01-14-2018 03:31 PM - edited 03-05-2019 09:45 AM
Scenario: 2 routers (R1 & R2) connected directly (point-to-point) via serial interfaces. Dual stack (IPv4 & IPv6). R1 is mine - I control it. R2 is not mine - I cannot control it or make any configurations on it.
I want to be able to block IPv6 ICMP echo replies from *MY* (R1's) serial interface back to R2's serial interface (e.g. not reply to pings sourced from R2's serial interface). Creating and applying an IPv6 ACL on R1's serial interface does not work - I guess because it only filters/blocks traffic going *through* the interface, not *to* the interface.
How else would I accomplish this?
Thanks!
PS - please ignore the 'logic' of this endeavor - it is purely academic.
Solved! Go to Solution.
01-15-2018 12:09 AM
Hi there,
Take a look at CoPP. You should be able to take the ACL you have configured and use it to define a class-map. Then create a new policy-map referencing your class map with the action drop, something like:
class-map match-all DROP-R2-ICMP
match access-group <YOUR_ACL>
policy-map RTR_COPP
class DROP-R2-ICMP
drop
control-plane
service-policy input RTR_COPP
cheers,
Seb.
01-15-2018 12:09 AM
Hi there,
policy-map RTR_COPP
class DROP-R2-ICMP
drop
control-plane
cheers,
Seb.
01-16-2018 10:48 AM
Seb
This worked like a charm - thanks! It's a bit of a 'long-way-round', but I can see a lot of ways to utilize this. Thanks so much for your help!
01-15-2018 11:09 AM
Interface ACLs in general do not normally block locally originated traffic. Have you tried blocking ICMPv6 echo request coming from R2 in an inbound ACL, rather than ICMPv6 echo reply to R2 in an outbound ACL.
01-16-2018 10:54 AM
Harold - thanks for the reply. I tried blocking requests and replies (e.g. ingress and egress) - unfortunately, due to the nature of ACLs in general, there never was really any hope for it to work for what I wanted it to do.Fortunately, Seb's solution was able to accomplish this. Given its operation at the control-plane level - it 'sees' the packets before the interface does and can filter on my criteria (albeit 3 layers deep ;-) ).
Thanks!
