How To Disable IPV6 on Cisco 6500 switch?
ersin erol
hi everyone,
  I want to learn that,on cisco switch (2950,3600,6500 series) IpV6 default open? İf It comes open on default,how to disable?
2 Accepted Solutions
This is your host send an MLD (IGMP for ipv6) report. The host is the one causing the problem. It looks like it has an HP nic at mac address 6431.5002.c6cf.
Personally, if you're not running IPv6, I'd find this host and disable ipv6 support....
** Please rate useful posts **
HTH, John *** Please rate all useful posts ***
In global config "ip igmp limit 100" will limit number of igmp messages.
Or under interface you can set igmp version 3 so that it wont cause you high cpu usage problem.
"ip igmp version 3"
19 Replies 19
Ivan Shirshin
By default ipv6 routing is disabled. To disable it you have to use the "no ipv6 unicast-routing" command.
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards,
Ivan
I tried on cisco 6500 series switch but this command didn't work,maybe another command?
What is your version? Do you have any output on "show ipv6 route"?
Kind Regards,
Ivan
Version:
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
I can not take output
"show ipv6 route"
Did you run the "no ipv6 unicast-routing" command in the configuration mode? What error did it give you (please post here)?
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi Ivan,
ı took this output ;
sw1(config)#no ipv6 unicast-routing
% Invalid input detected at '^' marker.
Could you do the "?" for ipv6 in config mode?
     sw1(config)#ipv6 ?
Kind Regards,
Ivan
sw1#sh version
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Mar-09 10:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
sw1 uptime is 2 years, 20 weeks, 3 days, 9 hours, 16 minutes
Uptime for this control processor is 2 years, 20 weeks, 3 days, 8 hours, 52 minutes
Time since sw1 switched to active is 2 years, 20 weeks, 3 days, 8 hours, 45 minutes
System returned to ROM by  power cycle at 12:12:09 UTC Tue Dec 8 2009 (SP by power-on)
System restarted at 03:34:32 GMT+2 Wed Jan 27 2010
System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI1.bin"
Last reload reason: VSLP HA role change from active to standby
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1328004C
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
54 Virtual Ethernet interfaces
390 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
sw1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
sw1(config)#ipv6 ?
% Unrecognized command
sw1(config)#ipv6
Ersin,
Why do you think it's enabled? It doesn't look like your IOS supports it...
John
I can't find a confirmation in release notices but it seems ipv6 is not supported in that IOS version. IpServices should have the ipv6 functionality.
Kind Regards,
Ivan
Kind Regards,
Ivan
Hi j.Blakley,
  there was a problem on the internal network,between vlans.At the same time run wireshark ı took this wireshark report. Thats why ı thougt this. But ı am not sure,What can be problem curtenly?
Image is
s72033-ipservices_wan-mz.122-33.SXI#.bin, where # is specific version.
Kind Regards,
Ivan
in our network we use ipv4, but this mac adress multicast ipv6 why it happend?
