Cisco 3945 misbehave, automatically defaults to rommod
Echo Chan
We have bought a Cisco 3945, when we tried to configure it, it appears to misbehave. It automatically defaults to rommod
during configuration/ operation, is there anyone experienced the same?
Giuseppe Larosa
Hello Echo,
a starting point is to verify the configuration register settings
follow this document to check and to eventually change the configuration register value
Typical value for a router like yours is 0x2102
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
you may have the break to rommon enabled that means the second hexadecimal digit not set.
Hope to help
Giuseppe
