how to display all tagged routes?
tititech2009
How to display all tagged routes?
I am redistributing bgp routes into ospf - I tagged all routes and I would like a quick way to display all tagged routes.
Right now, I can verify each tagged route one by one. But rather do it with one single command if possible.
Rack1R5#sh ip route 28.119.16.0
Routing entry for 28.119.16.0/24
  Known via "ospf 1", distance 110, metric 6000
  Tag 9999, type extern 2, forward metric 65
  Redistributing via eigrp 100
  Advertised by eigrp 100 metric 1000 10 255 1 1500
  Last update from 183.1.0.4 on Serial0/1/0, 00:17:39 ago
  Routing Descriptor Blocks:
  * 183.1.0.4, from 150.1.6.6, 00:17:39 ago, via Serial0/1/0
      Route metric is 6000, traffic share count is 1
      Route tag 9999
which command should I use to display all tagged routes?
you cannot view the routing table with tagged routes but you can surely scan the ospf database for tagged routes. use the following command
sh ip ospf summary-address | inc tag 9999
This is the best that you can get.
Please do mark if helpfull
Rustom Billimoria
CCIE R&S# 24798
Sent from my BlackBerry® smartphone from Tata Indicom
Captain82
Show ospfv3 rib detail <>
R4#sho ospfv3 rib det
OSPFv3 10 address-family ipv4 (router-id 4.4.4.4)
* 10.1.0.0/24, Intra, cost 65/0, area 0
source 3.3.3.3, tag 0
via 172.16.1.1, Serial2/0
* 10.1.1.0/24, Intra, cost 65/0, area 0
* 10.1.2.0/24, Intra, cost 65/0, area 0
