how to distribute traffic between ADSL lines
n.sebastian
We have a senario, A router with one FE and 4 ADSL WIC connected to the internet. Each ADSL gets ip address Dynamically form the same ISP. Can I load balance outgoing traffic to the internet with this 4 ADSL connection?. The FE port of the router is connected to a firewall, hence the outgoing traffic comes from a single source.
Can someone help me.
pkhatri
Level 11
Level 11
You certainly can do so. As long as you have four routes (each of them equal cost) pointing out each of these interfaces, then CEF will load-balance over these interfaces automatically, on a per-destination basis. It does not matter that all your traffic is coming from the same FE interface.
If you are using default routes, you can use something like the following:
ip cef
ip route 0.0.0.0 0.0.0.0 atm0.32
ip route 0.0.0.0 0.0.0.0 atm1.32
ip route 0.0.0.0 0.0.0.0 atm2.32
ip route 0.0.0.0 0.0.0.0 atm3.32
Hope that helps - pls rate the post if it does.
Paresh
Hi Pkhatri
How can NAT be handled?
Use a config such as the following (you will need to add IPs etc)
int FastEthernet0
ip nat inside
interface atm0.32
ip nat outside
interface atm1.32
ip nat outside
interface atm2.32
ip nat outside
interface atm3.32
ip nat outside
ip nat inside source route-map NATMAP1 interface atm0.32 overload
ip nat inside source route-map NATMAP2 interface atm1.32 overload
ip nat inside source route-map NATMAP3 interface atm2.32 overload
ip nat inside source route-map NATMAP4 interface atm3.32 overload
ip cef
route-map NATMAP1 permit 10
match interface atm0.32
route-map NATMAP2 permit 10
match interface atm1.32
route-map NATMAP3 permit 10
match interface atm2.32
route-map NATMAP4 permit 10
match interface atm3.32
Using the above config, each packet's source address will be NATed based on which interface it is switched out of, in a dynamic fashion.
Paresh
