How to dump ALL console message to a syslog file
Frank27
As per title. I would like to collect ALL message from a machine and dumping them inside a syslog file of 10 MB size that will overwrite it once it is reaching the size limit.
Is that possible and how?
 - Some devices support
pipe
command as to redirect output to  a file when showing the logs , and then copy file to external repository with tftp or scp. Note that it is always better to have a syslog server in place for operational follow-up and keeping longtime-logs as you wanted and or then your initial question 'disappears'
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 - As far as the first part of your question is concerned the
logging trap ...
command will determine the verbosity of syslog messages being send to the syslog server ,
logging trap debugging
being everything.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
i don't have a syslog server, i need to dump inside a single 10MB file  in the router itself for further reading
pipe
 M.
       Beauty and terror
      Just keep going
       No feeling is final
