how to enable debug on a gre tunnel and disable it
debnathgayatri
So, I tried to enable the debug on the tunnel using the command
xxx#debug interface tunnel 3
Condition 1 set
It did not show any traffic
And when i tried to remove the debug it said
xxx#no debug interface tunnel 3
This condition is the last interface condition set.
Removing all conditions may cause a flood of debugging
messages to result, unless specific debugging flags
are first removed.
Proceed with removal? [yes/no]:
% Operation aborted
Can someone explain this ?
I am trying to monitor the traffic on the tunnel
Julio E. Moisa
Try debug tunnel or  debug tunnel keepalive
to disable
u all  = undebug all
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
