IR829 Stuck in rommon -2
John.Barbour
I have a IR829 that is stuck in rommon -2
When I try to boot flash:ir800-universalk9-mz.SPA.156-3.M I get the following reading.
rommon-2> boot flash:ir800-universalk9-mz.SPA.156-3.M
Booting image: flash:ir800-universalk9-mz.SPA.156-3.M.... [Multiboot-elf, <0x
110000:0x9d764bc:0x4a85f8>, shtab=0xa32f2f8[csvds]:/ir800-universalk9-mz.SPA.15
6-3.M... , entry=0x1100b0]
[CU:0]
Jumps to: 0x1100b0
Smart Init is enabled
smart init is sizing iomem
TYPE MEMORY_REQ
Onboard devices &
buffer pools 0x03644000
TOTAL: 0x03644000
Rounded IOMEM up to: 55MB.
Using 12 percent iomem. [55MB/448MB]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.6(3)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 28-Jul-16 04:10 by prod_rel_team
<3> [691.241976] IOAPIC: IOAPIC 1 initialized, implementation version 32
<3> [691.241976] <E1000> e1000_device_init: initialized E1000 device
<6> PCI: Initializing
<6> PCI: Resetting devices
<6> PCI: Resetting device QAT15 (00:0b.0)
<6> PCI: Resetting device SMBUS1 (00:13.0)
<6> PCI: Resetting device ETH0 (00:14.0)
<6> PCI: Resetting device ETH1 (00:14.1)
<6> PCI: Resetting device ETH2 (00:14.2)
<6> PCI: Resetting device ETH3 (00:14.3)
<6> PCI: Finished resetting devices
<6> PCI: Restoring devices
<6> PCI: Finished Initializing
IOS image signature verification was: FAILURE
Autoboot string flash:ir800-universalk9-mz.SPA.156-3.M,12;
Failed to boot, skip first flash:ir800-universalk9-mz.SPA.156-3.M,12;
Are their any options or is this an RMA.
John
Leo Laohoo
IOS is corrupt.  Download the IOS again from the Cisco website.
Thank you Leo.
That is what I was thinking, but I wanted to make sure. I did see on Cisco.com that the 829 has this issue and may have to be a RMA. I will give this a try.
"IOS image signature verification was: FAILURE"? Two reasons:
1. The IOS is corrupt; and
2. An IOS bug.
Try to load with other IOS
Is there any other IOS available in flash?
15.6 version is the new stuff i would recommend to use 15.5.
Spooster IT Services Team
rommon-2> dir
flash:
MC7354_1102037_9903214_05.05.58.00_00_ATT_005.009_000
MC735X_9999999_9902574_05.05.58.00_00_GENNA_005.025_000
managed
eem
rommon-2>
this is what is showing in the directory.
The pickle is that this is a loaner from cisco for us to testing, and I cannot get the IOS from cisco.com because we have not officially purchased these yet.
