03-31-2008 02:52 PM - edited 03-03-2019 09:21 PM
Looking for commands to enable Qos on a 2811 router
thanks
03-31-2008 03:41 PM
What type of link do you have and what do you need QoS for ?
07-17-2008 11:35 PM
Just want to ask a simple question:
Do you have to enable 'mls qos trust dscp' on a router interface so that dscp values are allowed to persist through the router?
I tried to use the 'mls qos trust dscp' command on the router interface but the option is not there?
I am not even able to apply the command 'mls qos' globally to the router.
Thanks for help.
03-31-2008 05:32 PM
Assuming your running 12.3T or 12.4, you might start here: http://www.cisco.com/en/US/docs/ios/12_4/qos/configuration/guide/hqos_c.html
