how to erase config on asr 9000 from rommon?
rwhenson4422
i'm getting an error when the system boots up:
I made a mistake when configuring aaa authorization commands.  I can't make any changes while in this state.
Command authorization failed - 'AAA API' detected the 'fatal' condition 'No method could process the authorisation request'
Is there any way to erase config on asr9000 from rommon?
Mark Malone
yes you should be able to access the flash and delete it
are you in rommon , do you have the below options with delete ? if so you should be able to see the flash contents and then delete the cfg file
ROM Monitor Commands
Enter ? or help at the ROM monitor prompt to display a list of available commands and options, as follows:
rommon 1 > ?
alias					set and display aliases command
boot					boot up an external process
break					set/show/clear the breakpoint
confreg					configuration register utility
cont					continue executing a downloaded image
context					display the context of a loaded image
cookie					display contents of cookie PROM in hex
copy					Copy a file-copy [-b <buffer_size>] <src_file> <dst_file>
delete					Delete file(s)-delete <filenames ...>
dir					List files in directories-dir <directory>
dis					display instruction stream
dnld					serial download a program module
format					Format a filesystem-format <filessystem>
frame					print out a selected stack frame
fsck					Check filesystem consistency-fsck <filesystem>
help					monitor builtin command help
history					monitor command history
meminfo					main memory information
mkdir					Create dir(s)-mkdir <dirnames ...>
more					Concatenate (type) file(s)-cat <filenames ...>
rename					Rename a file-rename <old_name> <new_name>
repeat					repeat a monitor command
reset					system reset
rmdir					Remove a directory
set					display the monitor variables
stack					produce a stack trace
sync					write monitor environment to NVRAM
sysret					print out info from last system return
tftpdnld					tftp image download
unalias					unset an alias
unset					unset a monitor variable
xmodem					x/ymodem image download
mgazolo01
good morning
I have the same problem, as soon as you got the
