how to find the nvram details from cisco 4507 switches
phaniraj01
Dear Team,
Please provide the info to know the below details:
Available NV RAM, Used NV RAM, Available Flash, Used Flash
phani
Giuseppe Larosa
Hello Phani,
you can use
dir nvram:
dir nvram:
Directory of nvram:/
512 -rw- 7422 startup-config
513 ---- 57 private-config
514 -rw- 7422 underlying-config
1 ---- 0 rf_cold_starts
2 ---- 149 persistent-data
3 -rw- 0 ifIndex-table.gz
524280 bytes total (513677 bytes free)
and
dir /all to find all filesystems on the flash(es)
Hope to help
Giuseppe
Thanks for your quick reply,
we have only enable 10 previleges.
is there any other sh command
thanks,
phnai
