How to force DHCP server to assign a particaulr IP address in MPLS VPN
sasif
Apprecaite if somebody can answer the following:
R1 (Multi-VRF CE)------------R2(PE)
XYZ customer
XYZ customer connects to R2 via PPPoE.
Is there a way to assign XYZ customer a partiular IP address thru DHCP. The "host" command inside the dhcp pool doesnot work for the MPLS VPN. Is there a way to achieve this. Lets say the customer require to have 192.168.16.5 to be assigned to him all the time.
Here is the relevant config.
R1 config?
ip cef
no ip dhcp use vrf connected
ip vrf XYZ
rd 1:1
route-target export 1:1
route-target import 1:1
vpdn enable
vpdn ip udp ignore checksum
interface Ethernet1/0
ip address dhcp
duplex full
pppoe enable group 1
pppoe-client dial-pool-number 20
interface Dialer20
mac-address 000b.b220.3750
ip vrf forwarding ABC
ip address dhcp
ip mtu 1492
encapsulation ppp
shutdown
dialer pool 20
dialer-group 20
router ospf 100 vrf ABC
router-id 192.168.16.5
log-adjacency-changes
capability vrf-lite
network 192.168.16.0 0.0.0.0 area 0
network 192.168.17.0 0.0.0.0 area 0
R2 config
ip dhcp pool p20
vrf XYZ
network 192.168.16.0 255.255.255.0
ip vrf XYZ
rd 1:200
route-target export 1:2
route-target import 1:2
ip multicast-routing
vpdn enable
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 20
no ip address
ip access-group 102 in
duplex full
pppoe enable
interface Virtual-Template20
ip address 192.168.16.1 255.255.255.0
ip mtu 1492
peer default ip address dhcp-pool p20
router ospf 200 vrf ABC
redistribute bgp 1 subnets
network 192.168.16.0 0.0.0.255 area 0
fanjiehao8863
If there is no other good ways to solve this problem,I suggest u to set the ip address manually on the customers pc.So the customer can always have the ip address even under the condition of DHCP.
