How to get the BW details from the router
Dear ,
Can some one tell me how to get the bandwidth details after loging into router. I have the input interface details i.e the link from ISP. How to know the BW from this
johnlloyd_13
Level 9
Level 9
hi,
a lil info would help us answer your query. what termination or service are your referring to (metro-e, MPLS or DSL) and what router are you using? if this is a stub network (i.e. using a default route towards ISP next-hop IP address), then i would suggest to run an iperf test to get the best results.
Hi John,
Thnx for the reply, Service is MPLS and yes it is a stub network. It would be great if you can tell be how to do this iperf test, when i googled this i found this one to be a software . Is it possible to check without a software i.e directly by logging into router.
There's a hidden command in Cisco routers to verify this. I haven't personally used this on our routers but there were some discussions recently on this topic. You could also ask your SP to do Iperf test for you.
https://supportforums.cisco.com/thread/2126404
http://blog.derjohn.de/space/start/2008-08-15/1
