How to install IOS to cisco 881-w
jurijs_visockis
Hi. I formatted flash and now I need to install IOS .
I know than I have to do it using TFTPD, but I cant connect my PC and cisco.
On cisco throught console in putty I wrote :
rommon 1 > set
rommon 2 >    IP_ADDRESS=10.10.10.2
rommon 3 > IP_SUBNET_MASK=255.255.255.0
in pc local area connection
10.10.10.3 255.255.255.0
try to ping and no signal.
How to connect cisco and pc
5 Replies 5
Leo Laohoo
That's not complete.
Where's your TFTP server IP address?
Where's your default gateway IP address?
Where's the IOS file?
Cory Dryden
Straight from CCNA command guide. Once in rommon mode type following commands.
IP_ADDRESS=X.X.X.X
IP_SUBNET_MASK=X.X.X.X
DEFAULT_GATEWAY=X.X.X.X
TFTP_SERVER=X.X.X.X
TFTP_FILE=xxxxxxxxxx
tftpdnld
Once done type just the letter i to reload the router.
jurijs_visockis
Thank`s I did it.
Now I can`t configure WIFI, client didn`t get IP address,  there is my access point config
ap#sh run
Building configuration...
Current configuration : 2325 bytes
version 12.4
no service pad
hostname ap
enable secret 5 $1$dWJ8$Q7gffyWV3kiTNjDBwMvNn/
no aaa new-model
dot11 syslog
dot11 ssid D13VSK
   vlan 1
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 0 S13admin
username admin privilege 15 secret 5 $1$wNjR$5JBdFPNe4HV/srkkg2M2I1
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
broadcast-key vlan 1 change 30
ssid D13VSK
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface GigabitEthernet0
description the embedded AP GigabitEthernet 0 is an internal interface connecting A        P with the host router
no ip address
no ip route-cache
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
bridge-group 1 spanning-disabled
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
banner login ^CC
% Password change notice.
Default username/password setup on AP is cisco/cisco with privilege level 15.
It is strongly suggested that you create a new username with privilege level
15 using the following command for console security.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to
use. After you change your username/password you can turn off this message
by configuring  "no banner login" and "no banner exec" in privileged mode.
^C
line con 0
privilege level 15
login local
no activation-character
line vty 0 4
login local
cns dhcp
end
Now I can`t configure WIFI, there is my access point config
You need to be more specific than this!
jurijs_visockis
This is my router config
CiscoWifi#sh run
Current configuration : 3956 bytes
! Last configuration change at 11:33:28 UTC Sat Feb 11 2012 by admin
! NVRAM config last updated at 11:33:16 UTC Sat Feb 11 2012 by admin
version 15.2
no service pad
service password-encryption
hostname CiscoWifi
boot-start-marker
boot config flash:router-config
boot-end-marker
no logging console
enable secret 5 $1$LOzN$Ti9UiynDabsPapSTqmD.O.
aaa new-model
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-182589002
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-182589002
revocation-check none
rsakeypair TP-self-signed-182589002
crypto pki certificate chain TP-self-signed-182589002
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31383235 38393030 32301E17 0D313230 32313131 30313032
  365A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3138 32353839
  30303230 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C9FD8A23 4BD415F5 C02A81F4 71798DD1 5A577937 A1A3352C 05339EFE 95A667ED
  AF95CDE2 047F8E95 14E693AD 7E4D02B4 C98D4C69 A5C15EDD ABEF7C20 387D27E3
  48701545 2F9C72E2 6D6816BB 77ECC417 1DB2B09E A0619FA2 64FA8647 A2BDFBED
  EB324EF2 FEBC9F81 B60F75CF B89805F8 048909E5 9AF46F4A 1AA42756 B76D7065
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 168014EB 86D0BDBE 8C59FB90 BBA3E6A0 037D254B 48E49530 1D060355
  1D0E0416 0414EB86 D0BDBE8C 59FB90BB A3E6A003 7D254B48 E495300D 06092A86
  4886F70D 01010505 00038181 0053F16B 0B3656EA F019A12D E91E312E 3D3CE8F2
  0C95EF12 35173535 E3EA6242 97825ABD 4C90F487 47A3A2DB 3ACE3867 E4633D2B
  23623C2C 7A833E99 B760831F EC208D5D 215CB486 5E8EE68A AE4435C0 1166CB4B
  6840C38F EBFFF70E AF5F4FA9 B15A5089 49B3D1F5 FD966D93 C939621D DB605E55
  A742BABA 7DA88D79 AD4F8A81 98
        quit
ip dhcp excluded-address 10.13.10.1 10.13.10.4
ip dhcp excluded-address 10.13.10.201 10.13.10.254
ip dhcp pool dhcp1
import all
network 10.13.10.0 255.255.255.0
default-router 10.13.10.1
no ip domain lookup
ip domain name daug13vsk.lv
ip cef
no ipv6 cef
license udi pid CISCO881W-GN-E-K9 sn FCZ1432900Q
username user privilege 15 secret 5 $1$D0mB$ckLG9PDTTeOTjqcgH8jzQ0
username admin privilege 15 secret 5 $1$FbGR$jqb6b1SCdSi7DPTh5Zb5o1
username adm privilege 15 password 7 00374255055F060F01
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface Vlan1
ip address 10.13.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1 254
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 10.13.10.0 0.0.0.255
line con 0
exec-timeout 5 30
password 7 06355E724D4A04100B
line aux 0
line 2
no exec
transport preferred none
transport input all
line vty 0 4
exec-timeout 40 0
logging synchronous
transport input ssh
end
