How to IP NAT SIP trunk traffic to an IP PBX while using SIP handsets at the same time?
Matthew Needs
Hi All,
I've come across an issue to which I thought I had found the solution.. However, it didn't work and I don't fully understand why?   Take a look at the diagram and HW config attached FYI. The HQ site hosts a PBX with SIP trunks and the remote sites use LAN-LAN VPN to support a couple of SIP phones. Both trunks and the phones use UDP 5060 to register to the PBX. Hence the problem which I think due to my NAT config at the HQ!?...
I need to port forwardUDP 5060 to 172.16.16.2 (PBX) for the SIP service provider while at the same time allowing remote SIP Phones to register to the PBX. The trouble is i cant get both Trunks and Phones to work correctly at the same time!
I have removed my firewall ingress ACL from the config for now to keep things simple..
Thanks in advance for any help with this.
Matt
Matthew Needs
Hi All,
Suprised nobody has anything to say here! . Anyway, I think I may have found the problem (subject to tests).
Here's my original config:
version 15.2
no service pad
service password-encryption
hostname Head-Office
boot-start-marker
boot-end-marker
logging buffered 10000 informational
enable secret 5 ********
aaa new-model
aaa authentication login AUTH local
aaa session-id common
memory-size iomem 10
clock timezone GMT 0 0
clock summer-time brit_summer recurring
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 172.16.16.1 172.16.16.5
ip dhcp excluded-address 172.16.16.253 172.16.16.254
ip dhcp pool USERS
network 172.16.16.0 255.255.255.0
default-router 172.16.16.254
dns-server 8.8.8.8
ip name-server 8.8.8.8
ip inspect name INSPECT-OUT tcp
ip inspect name INSPECT-OUT udp
ip inspect name INSPECT-OUT icmp
ip inspect name INSPECT-OUT sip
ip inspect name INSPECT-IN sip
ip cef
login block-for 300 attempts 5 within 300
login quiet-mode access-class TELNET_RULES
no ipv6 cef
spanning-tree vlan 1 priority 4096
vtp mode transparent
username admin privilege 15 secret *******
controller VDSL 0
vlan 2
class-map match-any VOICE
match access-group name QOS_RULES
policy-map VOICEPOLICY
class VOICE
  priority 4000
class class-default
  fair-queue
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ******* address *******  no-xauth
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 30 periodic
crypto ipsec transform-set trans1 esp-3des esp-sha-hmac
crypto map VPNCRYPTO 1 ipsec-isakmp
set peer *******
set transform-set trans1
match address VPN1
crypto map VPNCRYPTO 2 ipsec-isakmp
set peer *******
match address VPN2
crypto map VPNCRYPTO 3 ipsec-isakmp
set peer *******
match address VPN3
crypto map VPNCRYPTO 4 ipsec-isakmp
set peer *******
match address VPN4
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface FastEthernet0
description *LAN*
switchport access vlan 2
no ip address
interface FastEthernet1
description *LAN*
no ip address
interface FastEthernet2
description *LAN*
no ip address
interface FastEthernet3
description *LAN*
no ip address
interface Vlan1
no ip address
interface Vlan2
description *INSIDE NETWORK*
ip address 172.16.16.254 255.255.255.0
ip nat inside
ip inspect INSPECT-OUT out
ip virtual-reassembly in
hold-queue 100 out
interface Dialer1
description *FTTC*
bandwidth 8000
ip address A.A.A.A 255.255.255.248
ip inspect INSPECT-IN in
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ********
ppp chap password ********
ppp ipcp dns request
no cdp enable
service-policy output VOICEPOLICY
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source route-map NAT interface Dialer1 overload
ip nat inside source static tcp 172.16.16.2 5060 A.A.A.B 5060 route-map GAMMA extendable
ip nat inside source static udp 172.16.16.2 5060 A.A.A.B 5060 route-map GAMMA extendable
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard TELNET_RULES
permit *********
permit *********
ip access-list extended QOS_RULES
permit ip any any dscp ef
permit ip any any precedence critical
ip access-list extended VPN1
permit ip 172.16.16.0 0.0.0.255 172.16.18.0 0.0.0.255
ip access-list extended VPN2
permit ip 172.16.16.0 0.0.0.255 172.16.17.0 0.0.0.255
ip access-list extended VPN3
permit ip 172.16.16.0 0.0.0.255 172.16.19.0 0.0.0.255
ip access-list extended VPN4
permit ip 172.16.16.0 0.0.0.255 172.16.20.0 0.0.0.255
access-list 100 permit ip 172.16.16.0 0.0.0.255 88.215.60.0 0.0.0.255
access-list 100 permit ip 172.16.16.0 0.0.0.255 88.215.61.0 0.0.0.255
access-list 100 permit ip 172.16.16.0 0.0.0.255 88.215.62.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 172.16.17.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 172.16.18.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 172.16.19.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 172.16.20.0 0.0.0.255
access-list 101 permit ip 172.16.16.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map GAMMA permit 10
match ip address 100
route-map NAT permit 10
match ip address 101
control-plane
line con 0
exec-timeout 15 0
privilege level 15
logging synchronous
login authentication AUTH
line aux 0
line vty 0 4
access-class TELNET_RULES in
exec-timeout 15 0
privilege level 15
logging synchronous
transport input all
ntp server ******** prefer source Dialer1
ntp server ********
end
Im thinking maybe it's my global PAT route-map matching SIP provider traffic before the NAT port forward route-map?! Im going to try and modify ACL 101 as follows in bold. I'll let you know what happens..
access-list 101 deny   ip 172.16.16.0 0.0.0.255 88.215.60.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 88.215.61.0 0.0.0.255
access-list 101 deny   ip 172.16.16.0 0.0.0.255 88.215.62.0 0.0.0.255
Matt
