how to know on what interface is the accesslist applied
Majed Zouhairy
I have a named access-list applied to some interface. I know the name of the access list but i do not know on what interface it is applied.there are lots of access-list on the 6500 switch so i'd rather not go guessing on what interface it is applied.
my imagination let me come out with the command:
sh run | section ip access-group WORD
but this does not begin with the interface name it only shows the next interface.
does any one know of a command to know where the access list is applied?
6 Replies 6
Wantser1981_2
You could try:
show ip interface | include line protocol | WORD
WORD = your access list name.
This will list all the IP interfaces, but also the lines below directly under the interfaces they are assigned to.
Outgoing access list is WORD
Inbound access list is WORD
ACL's can be used elsewhere obviously, but this might give you an idea of the L3 interfaces to which it is applied.
Andy
well it works but i have to list over quite a big list and the only other alternative mentioned on another site is:
sh run | I interface|access-group
which also shows a long list to search at.
anyway thanks for the help.
what about
sh run linenum | beg access-group WORD
That would give you the number of config line where the ACL is applied.
Let's say you get the line number 1170  from this output.
So the interface name should be visible just several lines before that line!
So sh run linenum | beg 1160 :
should show you the desired interface name.
Best regards,
Milan
it's funny my wife's family was Kulik
but on the 6500 l3 switch there is no such command:
switch#sh run ?
  all        Configuration with defaults
  brief      configuration without certificate data
  full       full configuration
  identity   Show identity profile/policy information
  interface  Show interface configuration
  map-class  Show map class information
  module     Show module configuration
  partition  Configuration corresponding a partition
  view       View options
  vlan       Show L2 VLAN information
  vrf        Show VRF aware configuration
  |          Output modifiers
but thanks for the effort
hopefully in some next IOS version...
In that case, I see only one possibility:
Download the config to your PC and use some handy file editor to search.
Or capture the output of
save it as a text file and again use some file editor.
Best regards,
Milan
You may try
show run access-group
Jagjeet
