how to load balance 2 routers with 2 wans
roneng
i have a 837 with adsl and 1841 with cable , both on the same lan. i want to use the wans to operate with load balance and also if one falls as backup
guruprasadr
Level 7
Level 7
HI,
For Load Balance with 2 Routers with WAN you can use HSRP Protocol.
Refer link below for HSRP Documents:
http://www.cisco.com/en/US/tech/tk648/tk362/tk321/tsd_technology_support_sub-protocol_home.html
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Thanx,
i understand, but is there a way to accomplish this without changing the default gateways at half the clients?
thomas.anthony
Please have 2 HSRP group created ( MHSRP )and one remain active in each WAN router by the help of Priority, and use track command for failover
http://www.cisco.com/en/US/customer/tech/tk1330/technologies_design_guide_chapter09186a008066670b.html#wp3389
