How to make a Frame relay cloud ...Help
bagvanliju
Hai,
i ve 3 routers and 2 L3 switches ...
2 1721 series
1 1821 series
2 3750 series
can i create "Simple" frame relay cloud using this ..if not how many routers are needed for this ....thought of doing ospf in frame relay cloud ...Help pls
ujil
Hello Ujil,
a good link is the following to FR switching config examples
http://www.cisco.com/en/US/docs/ios/12_1/wan/configuration/guide/wcdfrely.html#wp1002491
http://www.cisco.com/en/US/docs/ios/12_1/wan/configuration/guide/wcdfrely.html#wp1003624
When connecting routers back to back with serial interfaces you need :
to provide clock with clockrate on the interface were the DCE V.35 cable is connected (V.35 female to check cable use sh controller serial x/y but not supported on all platforms)
to define one side as the FR DCE that will behave as the FR switch (that here is not present).
Frame-relay DCE is defined on the router that performs frame-rel switching
Topology is simple : have every router connected with a serial interface to a serial interface of the router acting as FR switch
using the notes above.
Use on DTE routers point-to-point and point-to-multipoint subifs according to your needs to deploy different topologies.
Hope to help
Giuseppe
8 Replies 8
hai ,
thank for the info
ujil
Giuseppe Larosa
Hello lijesh,
to be able to emulate a FR cloud with a Hub router and two spokes you will need another router.
Try to find a 2500 router with 3 serial interfaces
Hope to help
Giuseppe
hai Giu,
thanks alot ...will try the same ....one more help reqrd ...cud u share the config/toplogy ...so it wud b easy for me ..to execute the same ...
ujil
Hello Ujil,
Hope to help
Giuseppe
Hai Giu,
Thanks a lot for the help will try to execut the same and let you know the status ...
thanks a lot once again
ujil
I currently am working on CCIE and had to emaulate a frame switch (frame cloud) I used (3) 3620 routers and as the frame switch 2514 I believe
If you need any help with the config let me know. Thanks and have a great day
hai,
unfortunatly i dont ve higher end router in my lab ..so ...would b difclt for me ...what i wanted was to get familiar with NBMA (practically) ...which used to me confuse me a lot ......if u can share the topology and config (if its simple ) i can go tru that ..
thanks alot
