How to make the GOS use 4g to connect with Internet?
JR_WU
Hello, everyone!
I met the question about how to make the Guest OS use 4G to connect with Internet on IR809. The Cisco IOS can use 4G to connect internet but GOS can't. Is there any configuration needed to make? I checked so many config guides but can't find the answer.
Thanks!
Vincent
Hello Vincent,
I don't think that works at all in ioX. It is for development only, you need a local USB or Ethernet hookup. 4G is not available in ioX.
