MPLS Internet Access from VRF: problem and best practice
UP82
Hi Everybody,
I'm doing some exercise about MPLS VPN and in particular Accessing Internet from a VRF.
As i understand there are 3 standard methods to accomplish that:
1) Using Global Routing Table with another physical interface or subinterface;
2) Using Global Routing Table with static and default-route;
3) Internet provided in a VRF with or without vrf-aware NAT;
I have some problem on point 3. This is my topology:
I had followed the tutorial on youtube called LabMinute SP0014 but i think that there is a mistake on it. I think that the configuration proposed have problem with overlapping ip addresses. Infact in my scenario CE3 can ping 8.8.8.8 but CE1 can't ping 8.8.8.8, but if i shut down PE1 f1/0 CE1 can ping 8.8.8.8.
I've found another explanation that try to explain the same scenario but with a different configuration. Instead of configuring vrf INTERNET and importing in it VRF A and VRF B, it tells that we must configure VRF A and VRF B also in PE2 and so on..
So my question is which is the best practice to accomplish internet in a vrf with overlapping ip address?
Paolo
PS: if it's necessary i can upload the configuration
Hello Pablo,
>> May be i should configure also the VRF A and VRF B on PE2 and than import the default route from VRF INTERNET. In this way there are no overlapping ip in the VRF INTERNET...(I think)
yes this should be the way to go. You were asking too much to PE2 how could it discriminate between overlapping addresses coming from two different VRFs defined on PE1?
Hope to help
Giuseppe
9 Replies 9
UP82
PE2 CONFIG
version 12.4
hostname PE2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
ip vrf INTERNET
 rd 2.2.2.2:1
 route-target export 2.2.2.2:1
 route-target import 1.1.1.1:1
 route-target import 1.1.1.1:2
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip tcp synwait-time 5
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
 ip ospf 1 area 0
interface FastEthernet0/0
 ip address 10.0.0.2 255.255.255.0
 ip nat inside
 ip virtual-reassembly
 ip ospf 1 area 0
 duplex auto
 speed auto
 mpls ip
interface FastEthernet0/1
 ip vrf forwarding INTERNET
 ip address 10.0.1.1 255.255.255.0
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet1/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet2/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet3/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface FastEthernet4/0
 no ip address
 shutdown
 duplex auto
 speed auto
router ospf 1
 log-adjacency-changes
router bgp 1
 no synchronization
 bgp log-neighbor-changes
 neighbor 1.1.1.1 remote-as 1
 neighbor 1.1.1.1 update-source Loopback0
 no auto-summary
 address-family vpnv4
  neighbor 1.1.1.1 activate
  neighbor 1.1.1.1 send-community extended
 exit-address-family
 address-family ipv4 vrf INTERNET
  no synchronization
  network 0.0.0.0
 exit-address-family
ip forward-protocol nd
ip route vrf INTERNET 0.0.0.0 0.0.0.0 10.0.1.2
no ip http server
no ip http secure-server
ip nat inside source list NAT-INTERNET interface FastEthernet0/1 vrf INTERNET overload
ip access-list extended NAT-INTERNET
 permit ip any any
no cdp log mismatch duplex
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
PE1 CONFIG
version 12.4
hostname PE1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf A
 rd 1.1.1.1:1
 route-target export 1.1.1.1:1
 route-target import 2.2.2.2:1
ip vrf B
 rd 1.1.1.1:2
 route-target export 1.1.1.1:2
no ip domain lookup
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 ip ospf 1 area 0
 ip vrf forwarding A
 ip address 192.168.1.2 255.255.255.0
 duplex auto
 speed auto
 ip vrf forwarding A
 ip address 192.168.2.1 255.255.255.0
 duplex auto
 speed auto
 ip vrf forwarding B
 ip address 192.168.3.1 255.255.255.0
 duplex auto
 speed auto
 ip address 10.0.0.1 255.255.255.0
 ip ospf 1 area 0
 duplex auto
 speed auto
 mpls ip
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 shutdown
 duplex auto
 speed auto
router ospf 2 vrf A
 redistribute bgp 1 subnets
 network 192.168.1.2 0.0.0.0 area 0
 network 192.168.2.1 0.0.0.0 area 0
router ospf 3 vrf B
 network 192.168.3.1 0.0.0.0 area 0
router ospf 1
router bgp 1
 no synchronization
 neighbor 2.2.2.2 remote-as 1
 neighbor 2.2.2.2 update-source Loopback0
 no auto-summary
  neighbor 2.2.2.2 activate
  neighbor 2.2.2.2 send-community extended
 exit-address-family
 address-family ipv4 vrf B
  redistribute connected
  redistribute ospf 3 vrf B
  no synchronization
 exit-address-family
 address-family ipv4 vrf A
  redistribute ospf 2 vrf A
  no synchronization
 exit-address-family
no ip http server
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 login
end
Configuring VRF Internet is common way.
Please share the output these commands on PE2
Show IP route vrf A
Show IP route vrf B
show IP route VRF Internet
Set "debug ICMP" on GW and ping from CE1 and CE2 and CE3. What do you see?
Masoud
PE2#show ip vrf A
% No VRF named A
PE2#show ip vrf B
% No VRF named B
I have only VRF INTERNET and i have imported VRF A and VRF B in it
PE2#show ip route vrf INTERNET
Gateway of last resort is 10.0.1.2 to network 0.0.0.0
172.16.0.0/32 is subnetted, 2 subnets
B 172.16.1.1 [200/2] via 1.1.1.1, 00:00:22
B 172.16.2.1 [200/11] via 1.1.1.1, 00:00:22
10.0.0.0/24 is subnetted, 1 subnets
C 10.0.1.0 is directly connected, FastEthernet0/1
B 192.168.1.0/24 [200/0] via 1.1.1.1, 00:00:22
B 192.168.2.0/24 [200/0] via 1.1.1.1, 00:00:22
B 192.168.3.0/24 [200/0] via 1.1.1.1, 00:00:22
S* 0.0.0.0/0 [1/0] via 10.0.1.2
As you can see from the VRF INTERNET table there is only one 172.16.1.1 (the overlapping ip address).
CE3#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 72/89/120 ms
CE3#ping 8.8.8.8 source loopback 0
Packet sent with a source address of 172.16.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/79/96 ms
GW#
*Mar 1 00:05:08.127: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
*Mar 1 00:05:08.219: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
*Mar 1 00:05:08.311: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
*Mar 1 00:05:08.435: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
*Mar 1 00:05:08.531: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
CE1#ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 68/95/128 ms
CE1#ping 8.8.8.8 source loopback 0
Success rate is 0 percent (0/5)
*Mar 1 00:08:23.307: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
GW#
*Mar 1 00:08:26.047: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
GW#
*Mar 1 00:08:29.183: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
GW#
*Mar 1 00:08:32.027: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
GW#
*Mar 1 00:08:34.931: ICMP: echo reply sent, src 8.8.8.8, dst 10.0.1.1
Hello Pablo,
Hope to help
Giuseppe
I' like to ask one last thing:
Is it necessary configure VRF INTERNET?
I mean, i could configure on PE2 only VRF A and VRF B and than create one default route for VRF A and one for VRF B without configuring VRF INTERNET...... right?
The benefit of configuring VRF INTERNET is that it allows to configure only one default-route and than redistribute to the other VRF (the process is more automatized) right?
As for your question about VRF internet, it is easy to implement if you do not have IP overlap or you can handle overlap on customer side. You just need to play with export and import  inVRFs.
If you use global routing table instead, you need to create all VRFs on PE router connected to internet and then use PBR to direct the return traffic to each VRF.
Hope it helps,
Masoud
Actually, it is complicated when you have overlapped IP.
If you do not have overlapped IP, you do not need to create VRF A and VRF B when VRF INTERNET is configured .
If you have overlapped IP, you need to use other ways. I do not think it is possible with using common Internet VRF. It is possible to use common service such as a server(in your case only 8.8.8.8) but for entire internet address, it is not possible.
Even for a common server, it is complicated. Let me know if you need help with only your scenario( pinging only some specific addresses such as 8.8.8.8, not entire internet;
Masoud
Check my previous comment before. Check your NAT also.
Do this test also.
Consider two IPs for NAT.
NAT all VRF A IPs to 10.0.1.10
NAT all VRF B IPs to 10.0.1.20
Masoud
I want ask you can C1 ping to C3 ? because both had a default route in there routing table.
