How to match specific http or P2P protocol using QoS with IOS 12.4(11)T
ntpower
Previously with IOS 12.4(5) or earlier where we can do things like 'match protocol http mime <type>' and match P2P protocols on QoS in class-map, however with 12.4(11)T I cannot find it anywhere.
Is there anyone who knows how it this can be done? as I would like to restrict and shape the traffic for P2P traffic, and allow VoIP and other http traffic to have higher priority.
PS: For Cisco 871 and 877 specifically.
Thanks.
Hieu Cao
Level 4
Level 4
Is "match protocol" not an option anymore in 12.4(11)T? I don't have cisco 871/877, but perhaps you can use ip nbar port map custom-xx to identify your protocols/ports that way, provided that "match protocol" is still an available option.
Perhaps someone else can shed some lights on this.
hth
hieu
jackyoung
Level 6
Level 6
According to the command reference of 12.4T, it should support mentioned commands.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tqos_r/qos_m1ht.htm#wp1137944
Could you advise which level parameter do not allowed to enter ? Could you try to type "?" at the level that display error ? e.g. "match protocol http ?"
Check below for the config. guide :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt8/qcfmcli2.htm
Hope this helps.
