How to NAT on different way
shahid_duet
Dear friend
I am using 3845 router at Head office. My server should reachable from different network. I am using Static nat as follows :
ip nat inside source static 192.168.0.14 172.25.40.118 route-map NAT_25
ip nat inside source static 192.168.0.14 172.30.40.118 route-map NAT_30
route-map NAT_25 permit 10
match ip address 2001
route-map NAT_30 permit 10
match ip address 2002
The NAT does not work properly. When i ping to 172.30.40.118, 192.168.0.14 dose not response. but when i continue reverse ping to remote IP than 192.168.0.14 respond.
Is there another nating procedure that will nat multiple ip to One IP ?????
Please suggest me.
Shahid
John Blakley
Shahid,
You could try changing both of your nat statements to:
ip nat inside source static 192.168.0.14 172.25.40.118 extend
ip nat inside source static 192.168.0.14 172.30.40.118 extend
This will map both 172.30.40.118 and 25.40.118 to the 192.168.0.14. Will that work for you?
HTH,
John
HTH, John *** Please rate all useful posts ***
