How to NAT one inside ip to multiple outside ips in asa firewall
narasimha rao
Dear Friends,
i have a problem with asa 5500 series firewall,can you guys help me.
Problem:
inside-ip -----> NAT -------> two outside networks
Connectivity:
1.i have two isp's  and connected to two different interfaces in asa fw.
2.i have one inside network(ip) and its connected to another interface in asa fw.
3.With these two ISP's through site-to-site vpns are running,but this inside ip not accessing if one is down.
Example Configuration:
Hi ,
 Are you accessing this internal host via S2S IPSEC tunnel ?? or via NAT public IP address .
Sandy
via NAT accessing public ips.
Hi ,
kindly share me your firewall config .
sandy
prajithtr_2
its not clear ..could you give the configuration.
PrajithTR
