How to optimize my Internet access?
Hi have 4 E1 FR configured on my router to the internet access.
We have about 2000 concurrent connections to internet over these links.
We have a lot of congestion on the links as show on she config:
What can I do to try to increase my performance an have a better internet access?
I really appreciate your help!
All my serial interfaces are configured as follow, I send the ACL too
interface GigabitEthernet0/1
description To my LAN
bandwidth 11520
ip address 172.24.24.1 255.255.255.0
ip access-group Trafico_OUT in
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip inspect Firewall in
ip nat inside
ip virtual-reassembly
load-interval 30
duplex full
speed 1000
media-type rj45
no mop enabled
interface Serial0/0/0
description To MY ISP
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
serial restart-delay 0
frame-relay lmi-type ansi
interface Serial0/0/0.531 point-to-point
description ConexionISP
bandwidth 1920
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip access-group Trafico_IN in
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
frame-relay interface-dlci 531 IETF
cisco_lad2004
Level 5
Level 5
1st of all u have to be realistic. what is your ratio BW/customer ??
if you cannot buy more capacity than what u have now, you can implement QOS and ensure scavenger and peer 2 peer traffic is dropped.
for example you priorities ur email, DNS service and http.
but I think ur problem is the available BW shared by so many users.
Sam
ROBERTO TACCON
Level 4
Level 4
which are the configuration timers parameters of the nat fot tcp /udp ? and for the FW inspection ?
with the nbar feature wich P2P protocols the router find ?
can you paste the sh ver/run/nbar configuration ?
I r.taccon I post my config thanks for your help
? Why on the router conf. You choose the:
ip cef load-sharing algorithm tunnel
http://www.cisco.com/en/US/docs/ios/12_2/switch/command/reference/xrfscmd2.html#wp1062329
With the snmp have you check the load-sharing between the serial interfaces (with time frame do you use to pool the interface (5 minutes or less: try 5/10 seconds)?
Are the IP traffic shared well ?
