Config Dual T1 DSU card- 2800 series
thaman303
After inserting the card in the Router slot, I don't see the additional controller T1 available, show version tells additional 2 channelized T1's.
How can I configure serial interfaces now ? pelase help.
Configure "card type t1 " first.
Controllers will appear, for a full T1 configure "channel-group 0 timeslots 1-24".
Serial interface will appear, configure it as usual.
5 Replies 5
paolo bevilacqua
Which card exactly ? Do show diag to know.
Its VWIC2-2MFT1-T1/E1 2 ports
Thanks much.
No worries, it happens a lot with the vwic2.
Thanks for the nice rating and good luck!
