How to remove subnetted route on Catalyst 3560
imanco671
Hello Community,
I have been researching a way to remove this subnetted route from my L3.
There is an extra subnetted route that should not be there when I execute the command: show ip route
Below if part of my Show Run and the Show IP Route commands. You will see the 10.0.0.0/24 subnet as subnetted. I dont know why the L3 uses the 10.0.0.0/24 when I enter 10.10.10.0/24? But thats a whole different questions.
Thanks Community and sorry if I ask so many questions! I am new and getting the hang of the cisco world b/c of all of you!!!!
John
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 10.10.10.1 255.255.255.0
interface Vlan3
ip address 192.168.202.1 255.255.255.0
interface Vlan4
ip address 192.168.200.1 255.255.255.0
interface Vlan5
ip address 192.168.210.1 255.255.255.0
router rip
version 2
redistribute static metric 1
network 10.0.0.0
network 192.168.200.0
network 192.168.202.0
network 192.168.210.0
network 192.168.220.0
no auto-summary
ip classless
ip route 10.10.10.0 255.255.255.0 10.10.10.222
ip route 192.168.3.0 255.255.255.0 192.168.200.254
ip route 192.168.5.0 255.255.255.0 192.168.200.254
ip route 192.168.98.0 255.255.255.0 192.168.200.254
ip route 192.168.102.0 255.255.255.0 192.168.200.254
ip route 192.168.103.0 255.255.255.0 192.168.200.254
ip route 192.168.104.0 255.255.255.0 192.168.200.254
ip route 192.168.105.0 255.255.255.0 192.168.200.254
ip route 192.168.110.0 255.255.255.0 192.168.200.254
ip route 192.168.111.0 255.255.255.0 192.168.200.254
ip route 192.168.112.0 255.255.255.0 192.168.200.254
ip route 192.168.113.0 255.255.255.0 192.168.200.254
ip route 192.168.150.0 255.255.255.0 192.168.200.254
ip route 192.168.151.0 255.255.255.0 192.168.200.254
ip route 192.168.154.0 255.255.255.0 192.168.200.254
ip route 192.168.155.0 255.255.255.0 192.168.200.254
ip route 192.168.200.0 255.255.255.0 192.168.200.254
ip route 192.168.202.0 255.255.255.0 192.168.202.222
ip route 192.168.214.0 255.255.255.0 192.168.200.254
ip route 192.168.220.0 255.255.255.0 192.168.210.222
ip http server
snmp-server community public RO
control-plane
line con 0
line vty 0 4
password T3m5xlD2D62
login
line vty 5 15
login
end
arouter#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
S    192.168.104.0/24 [1/0] via 192.168.200.254
S    192.168.151.0/24 [1/0] via 192.168.200.254
S    192.168.105.0/24 [1/0] via 192.168.200.254
C    192.168.210.0/24 is directly connected, Vlan5
S    192.168.150.0/24 [1/0] via 192.168.200.254
S    192.168.110.0/24 [1/0] via 192.168.200.254
S    192.168.111.0/24 [1/0] via 192.168.200.254
S    192.168.214.0/24 [1/0] via 192.168.200.254
C    192.168.200.0/24 is directly connected, Vlan4
S    192.168.98.0/24 [1/0] via 192.168.200.254
S    192.168.5.0/24 [1/0] via 192.168.200.254
C    192.168.202.0/24 is directly connected, Vlan3
     10.0.0.0/24 is subnetted, 1 subnets
C       10.10.10.0 is directly connected, Vlan2
S    192.168.113.0/24 [1/0] via 192.168.200.254
S    192.168.112.0/24 [1/0] via 192.168.200.254
S    192.168.102.0/24 [1/0] via 192.168.200.254
S    192.168.220.0/24 [1/0] via 192.168.210.222
S    192.168.103.0/24 [1/0] via 192.168.200.254
S    192.168.155.0/24 [1/0] via 192.168.200.254
S    192.168.154.0/24 [1/0] via 192.168.200.254
S    192.168.3.0/24 [1/0] via 192.168.200.254
5 Replies 5
cadet alain
Hi John,
this is normal. the 10 network is a class A(/8) private IP address but you gave it a /24 mask so it is subnetted.
Regards.
Alain
just to add to what Alain said, in other words, the "sh ip route" output means that 10.0.0.0/8 was subnettet into /24 subnets  and then shows exactly  /24's which are known.
I suppose It's for  "backwards" compatibility  with a class-full routing (which nowdays shoudn't be used anymore).
How can I remove that extra subnetted route?
I tried using the command, but was unsuccessful: no ip route 10.0.0.0/24
you can't remove it, and its not a "extra subnetted route". As I said it's just an information. if you put some additional subnets in 10.0.0.0, they will be all showed after line "  10.0.0.0/24 is subnetted, 1 subnets" in "sh ip route".
update: do you aware about what  "no ip route 10.0.0.0/24" command  exactly does?
As Konstantin said you can't remove it , it is a connected route. if you really want not to see it anymore then use a /8 instead.
ip route is for configuring a static route so it has nothing to do with connected routes and you have to specify the subnet mask not the prefix-length.
Regards.
Alain
