how to report a BUG
vladrac-ccna
Level 5
Level 5
Hello everyone,
I believe Ive ran into a bug in a new IOS version for a catalyst.
Is there a way to report this?
Vlad
royalblues
Level 10
Level 10
Raise a TAC case and they will let you know whether your assumption is already documented as a BUG.
Narayan
Also you can verify the bug has been already listed in the buglist.
you can refer this link for the same..
http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl
regds
Actually, Ive found the same behaviour on an old BUG, on a different IOS version and platform.
Not sure if is still good to mention as this is for the latestest IOS on a Catalyst.
Is there a way to do it without a TAC?
thanks again
Vlad
