How to reset user name on Cisco Catalyst 3550
epanduro1
Is there a way to reset user name on a Cisco Catalyst 3550 series switch. I was able to reset the password, but it turns out that the user name was also changed.
johnlloyd_13
Level 9
Level 9
hi,
yes, if you can get to privilege/global config mode (Switch#)
try to do:
no username
username <username> privilege 15 password <password>
