how to restore router with PKI certs.
Desmond Lee
hi, I have a router with 2 PKI certs from production environment.  The configuration is something like below. (only PKI related info are shown)  How do I transfer everything from here to another router if it fails ?
1. Can i just copy the whole running or startup config to the new router ? Will it auto generate the .cer files to the nvram ?
2. Or use the "crypto pki enroll "trustpoint name" command to request for the new certs ? But how do I generate 2 certs from a CA ? Got something like the below - only 1 cert max.
"Trustpoint xx has already enrolled and has a router cert issued to it.
If you successfully re-enroll this trustpoint,the existing certificate will be replaced."
Thanks in advance for any advice.
crypto pki trustpoint CA1
 enrollment mode ra
 enrollment url http://1xx.6x.8x.1xx:80/certsrv/mscep/mscep.dll
 revocation-check none
 source interface Loopback0
// the 2 certs below as shown in running-config, both under CA1
crypto pki certificate chain CA1
 certificate 6xxxxxxxxxxxxxxxx36
(truncated data key)
certificate ca 5xxxxxxxxxxxxxxxxxxxxxxxxx80C
//info of the certs
(router) #sh crypto pki certificates
Certificate
  Status: Available
  Certificate Serial Number (hex): 6xxxxxxDxxxxxxxxxx36
  Certificate Usage: General Purpose
  Issuer:
    cn=xxxxxxxxx_SVR01_Z
  Subject:
    hostname=xx.xx.gov.xx
  Validity Date:
    start date: 14:10:25 GMT Jul 23 2015
    end   date: 14:20:25 GMT Jul 23 2020
  Associated Trustpoints: CA1
  Storage: nvram:#36.cer
CA Certificate
  Status: Available
  Certificate Serial Number (hex): 5xxxxxxxxxxxxxxxxxxxxxxxxxxx80C
  Certificate Usage: Signature
  Issuer:
    cn=xxxSVR01_Z
  Subject:
    cn=xxxxSVR01_Z
  CRL Distribution Points:
    http://xx_ca1/CertEnroll/xxxxxx.crl
  Validity Date:
    start date: 09:56:36 GMT Jun 6 2011
    end   date: 10:05:45 GMT Jun 6 2021
  Associated Trustpoints: xxCA1
  Storage: nvram:#F80CCA.cer
Directory of nvram:/
  236  -rw-       15448                    <no date>  startup-config
  237  ----        3795                    <no date>  private-config
  238  -rw-       15448                    <no date>  underlying-config
    1  -rw-        2945                    <no date>  cwmp_inventory
    4  ----         118                    <no date>  persistent-data
    5  ----           0                    <no date>  rf_cold_starts
    7  -rw-         694                    <no date>  ifIndex-table
    8  -rw-        1255                    <no date>  #36.cer
  12  -rw-        1446                    <no date>  #F80CCA.cer
END
Julio E. Moisa
You cannot just copy and paste it on other router, basically you must generate tthe certificate using the following commands (step by step):
1) crypto pki trustpoint <name of the server/trustpoint>
2) crypto pki authenticate <name of the server/trustpoint>
    crypto pki authenticate CA1
3) crypto pki enroll <name of the server/trustpoint> , here, it will request a password configured on the server/trustpoint when the certificate was created.
    crypto pki enroll CA1
Now remember that Server/trustpoint and the client router must have the same date and time to sync, you can use NTP or modify the date/time manually to match or to be a little bit high on the client.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio, thanks.
But I do have a little problem with generating more than 1 cert from the same trustpoint.
From my current config, I do have 2 certs.
but when I try enrolling more than once, it will say something like "this trustpoint already had a cert, the current cert will be replaced, do you want to continue ? (yes/no)"
any advice for this ?
