08-10-2007 01:16 AM - edited 03-03-2019 06:16 PM
My router: Cisco 1841 with 2 SHDSL modules
My requirement:
Route all traffic from ATM 0/0/0 to FastEthernet 0/0
Route all traffic from ATM 0/1/0 to FastEthernet 0/1
The 2 ATM interfaces are 4 wire point to point links.
There are 2 /29 subnets to route, one on each ATM interface.
How to go about this?
08-10-2007 03:15 AM
You need policy routing for this.
Search PBR on CCO, but in short you make configure 4 route maps, and apply them on the appropriate interface or subinterface:
each route map simply specifies the next hop or interface:
match interface ...
set ip next-hop ...
Thta should do it.
08-11-2007 08:27 PM
Hi There,
I got the following advice from a Cisco tech:
(Assumptions)
ATM 0/0/0 = client1 PPP link to ISP
ATM 0/0/0 has subnet 203.200.200.0/29 routed to it (By ISP).
Remote end of PPP link = 125.22.33.1
Local end of PPP link = 125.22.33.2
ATM 0/1/0 = client2 PPP link to ISP
ATM 0/1/0 has subnet 203.200.201.0/29 routed to it (by ISP).
Remote end of PPP link = 125.22.33.5
Local end of PPP link = 125.22.33.6
fastethernet 0/0 = For client1
fastethernet 0/1 = For client2
access-list 15 permit any
route-map client1 permit 10
match ip add 15
set ip next-hop 125.22.33.1
interface fastethernet 0/0
ip policy route-map client1
ip address 203.x.x.1 255.255.255.248
route-map client2 permit 10
match ip add 15
set ip next-hop 125.22.33.5
interface fastethernet 0/1
ip policy route-map client2
ip address 203.200.201.1 255.255.255.248
This setup fails, it has several problems.
1. If I ping any of the ATM interfaces
125.22.33.2 or 125.22.33.5 from the
router at the other end of the PPP
connection there is a reply but if going
1 hop or more away from the remote end
router, it fails (From Internet).
2. If I ping the 2 fastethernet IP's from
other end of their respective PPP links
there is a reply but moving 1 or more
hops away from the remote end router,
3. All routing by ISP has been tested and
found to be OK. This was tested by
changing the configuration to
"ip route 0.0.0.0 0.0.0.0 125.22.33.1"
while removing the policy statements.
4. I tested
"ip route 203.200.200.0 255.255.255.248
125.22.33.1", trying to force a route but
that got me nowhere fast.
5. Finally I tested advanced ping by setting
ping source address to 203.200.200.1
(fastethernet 0/0 IP) and pinging the
remote end of the PPP link 125.22.33.1
and this worked but repeating the ping
to a known working IP on Internet fails.
It is as if something is missing. My Cisco
experience is only limited, what to do next.
In Linux it is quite easy to do the above
by simply setting a route rule up to
tell the kernel to route all traffic on one
interface to another. Cisco does not have
that capability (Not directly anyway).
I am now a bit stuck...
Best regards
08-11-2007 09:55 PM
you can define a light vrf place ATM0/0/0 and F0/0 under that VRF as long as there is no relation ship between ATM0/0/0 and ATM0/1/0
Br,
FH
