How to route between 2 vlans through a router and between different location?
shalmanov
I've got 2 vlans (100 and 101) that come to a port of switch. Vlan100 has to ping vlan101 through router and also next site with different network.
See the attached file for more info. Please give a good example to do it. Thank you.
2 Accepted Solutions
shivjain
hi
on R1 you have to craete two sub interfaces for vlan 100 and 101.
on R2 also you have to craete two sub interfaces for vlan 100 and 101.
Between Gi2/1 on R1 and R2 you have to enable the routing either static or dynamic.
Config on R1 will look like as below:-
int gi0/1.100
ip address 10.30.148.x
int gi0/1.101
ip address 10.30.149.x
int gi2/1
ip address 1.1.1.1 255.255.255.252 (Assuming)
ip route 10.30.150.0 255.255.255.128 1.1.1.2
ip route 10.30.150.128 255.255.255.128 1.1.1.2
Config on R2 will look like as below:-
int gi0/1.100
ip address 10.30.150.x
int gi0/1.101
int gi2/1
ip address 1.1.1.2 255.255.255.252 (Assuming)
ip route 10.30.148.0 255.255.255.0 1.1.1.1
ip route 10.30.149.128 255.255.255.0 1.1.1.1
regards
shivlu jain
www.mplsvpn.info
Please check the below config of switches:-
1. int fa0/0
description port connected to host pc
switchport mode access
switchport access vlan 100
no shut
2. int fa0/48
description port connected to router
switchport mode trunk
switchport trunk encapsulation do1q
switchport trunk allowed vlan 100,101
no shut
Please close the thread if it solves your problem.
regards
shivlu jain
shivjain
hi
int gi0/1.100
int gi0/1.101
int gi2/1
int gi0/1.100
int gi0/1.101
int gi2/1
regards
shivlu jain
www.mplsvpn.info
thnks for replying,
it will be great if you give a example for config of switches.
regards aga
1. int fa0/0
no shut
2. int fa0/48
no shut
regards
shivlu jain
