how to run ASA in gns3
salman abid
I'm facing some issue while useing ASA in gns3.....i have already attach the gns topology in which i'm not able to get the console of asa also i have attached the snapshoot in which u can see BOOTING THE KERNEL but in other window of asa console cli mode is not coming
can any body check what is the issue?????????????????????????????
i need to practise asa on gns3
thanx
blau grana
Level 7
Level 7
Hello Salman,
You have no parameters defined in Qemu options line.
Try to follow this tutorial -> http://forum.gns3.net/topic2784.html
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
Hello Salman,
Best Regards
@ blau grana
Thanks man
it works
The connection can't be opened, I haven't solved this problem yet, can you help me ?please
