Hello.
The community attribute can be seen by using "show ip bgp x.x.x/x".
Example-
route-views.oregon-ix.net>show ip bgp 3.0.0.0/8
BGP routing table entry for 3.0.0.0/8, version 41880288
Paths: (49 available, best #15, table Default-IP-Routing-Table)
Not advertised to any peer
3549 1239 80
208.51.134.254 from 208.51.134.254 (67.17.81.162)
Origin IGP, metric 0, localpref 100, valid, external
Community: 3549:2141 3549:30840
---snip---
Then if you wanted to see all routes with a particular community you could use "show ip bgp community aa:nn"
route-views.oregon-ix.net>show ip bgp community 3549:2141
BGP table version is 48334427, local router ID is 198.32.162.100
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 3.0.0.0 208.51.134.254 0 0 3549 1239 80 i
* 4.0.0.0 208.51.134.254 0 0 3549 3356 i
* 4.17.225.0/24 208.51.134.254 0 0 3549 701 11853 6496 6496 6496 6496 i
* 4.17.226.0/23 208.51.134.254 0 0 3549 701 11853 6496 6496 6496 6496 i
* 4.17.251.0/24 208.51.134.254 0 0 3549 701 11853 6496 6496 6496 6496 i
* 4.17.252.0/23 208.51.134.254 0 0 3549 701 11853 6496 6496 6496 6496 i
---snip---
I think this is what you were looking for.
-Rob
