how to send POP-up message using router
smothuku
Level 7
Level 7
Hi All,
Is there any command for sending pop-up messages to all the pc's connected in Lan from router ?
I want to send single message from router to all PC's connected in Lan.
Thanks in advance.
Satish
vijayasankar
Level 4
Level 4
AFAIK there is no such command to do that.
-VJ
mario35
There is a "send" command that you can send a message to:
* All tty lines
<0-16> Send a message to a specific line
console Primary terminal line
log Logging destinations
vty Virtual terminal
Router#send *
Enter message, end with CTRL/Z; abort with CTRL/C:
Joseph W. Doherty
Well first the PCs would need to be running some form of messaging app that would "see" and display a message.
Assuming that's the case, depending on the platform, it might be possible to send a message via an on-board router script.
