How to setup ENET ENCAP/LLC
meijbergj
I wan't to setup my 877 router but according to my provider i have to use the folowing setup items:
VPI = 0
VCI = 34
Multiplexing = LLC
HDLC framing = never
Protocol = ENET ENCAP/LLC
Who can help me with a setup file? Never heard of an encapsulation called "ENET ENCAOP/LLC" and i don't know if my cisco router supports it?
Please help
Regards, John
meijbergj
SOlved.
Just use AAL5SNAP !!!
Hi meijbergj,
I have the same issue boggling my mind for a long time now. Would it be possible for you to share the configuration that you used?
Thank you!
