How to show maximum routing table in router 1900
TimeOut
Hi anyone
How to show maximum routing table in 1900 using ios > Version 15.6(3)M7
I tried show  command as below
-show platform tcam
Platform EHWIC Switch TCAM Software information
and show sdm  << no have command
Do you have command show it ?
thank for help
balaji.bandi
Not sure if my answer suite your need :
show ip route summary (is that works for you ?)
BB
Giuseppe Larosa
Hello @TimeOut ,
a cisco 1900 is a software based router and not a multilayer switch
for this reason there is no SDM template concept and there is no TCAM size to deal with.
You need to look at the output of show version
This will give you the total amount of RAM memory.
The max number of routes depends on the RAM size in a software based router.
Each prefix will be in the IP routing table and in the CEF FIB table.
Also the CPU power is important for CEF table refresh.
In any case a Cisco 1900 is far from being able to support a BGP full table of more then 700,000 routes
I would expect it to be able to handle 10,000 routes to 20,000 routes.
Hope to help
Giuseppe
thank for answer
