08-25-2020 06:02 AM
The results of my 'sh ip bgp vpnv4 all'
BGP table version is 5, local router ID is 3.3.3.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path, L long-lived-stale,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 45:1 (default for vrf PN2)
*> 212.45.254.0/30 0.0.0.0 0 32768 ?
* 213.45.1.0/30 0.0.0.0 0 32768 ?
*> 0.0.0.0 0 32768 ?
Route Distinguisher: 100:1 (default for vrf CAR-G3)
I would expected that he selects the known and leaked routes?
Situation: On a router I have two VRF (CAR-G3 and PN2).
Via the PN2 a tunnel arrives and that tunnel is inside that VRF.
It serves to receive a secondary tunnel. But then the router needs to connect to VRF CAR-G3. Therefore i did route leaking on that router with route export and import. I can see that the routes are known on both in the BGP session.
The BGP session is:
router bgp 1
bgp router-id interface Loopback0
bgp log-neighbor-changes
address-family ipv4 vrf CAR-G3
redistribute connected
exit-address-family
address-family ipv4 vrf PN2
exit-address-family
I think: that it is possible via ip prefix list capturing the routes and adding a BGP local preference to them via a route-map that is then linked in the vrf's exports.
So any help thought or directions is well received.
Thank you
Bart
08-25-2020 07:22 AM
Hello @_|brt.drml|_ ,
in the show ip bgp and shw ip bgp v a
when there are multiple paths to a prefix the prefix is reported only the first time
so the following:
this means there are two paths to 213.45.1.0/30 and both of them are locally generated next-hop = =.0.0.0.0 means locally generated and also the weight 32768 means locally generated.
It is not clear why the second path is preferred as we cannot see all the BGP attributes.
You can check this using
show ip bgp vpnv4 all 213.45.1.0/30
Likely an imported route is not preferred over a route learned via redisribute connected.
Hope to help
Giuseppe
08-26-2020 04:23 AM
